Add-in DFX4Laser missing
I added DFX4Laser. When I wanted to edit it to make it working as said (Change 2 lines in the code), the editing didn't work.
I tried to repair the add-in, didn't work. I tried to desinstall and reinstall it, didn't work.
I tried again deleting DFX4Laser from the add-ins list and reinstall again, this time didn't appear in the list.
I disinstalled and reinstalled Fusion an dtried all the above and nothing worked.
What can I do ? I need this add-in for cutting pieces.
PinRudolf
I'm not familliar with this tool but this might help:
Could you check if the files are still installed in
C:\Users\User\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns
(This is the normal install location)
If they are; you might be able to connect to the files again using the Script and Add-ins menu. Klik on the green plus to add a folder containing the add-in. (make sure you chose add-in or Script according to the tool) This, at least, should add it to the list again.
The reason why de add-in does not work should probably be asked the developer. (I can't find this add-in, is it a github add-in?)
Hi PinRudolf,
Thanks for your answer.
The add-in is not in the specified directory.
I don't  know why.
You can find this add-in here :
https://apps.autodesk.com/FUSION/en/Detail/Index?id=7634902334100976871&appLang=en&os=Win64
Regards
