Add entries to context menu for dimension?
I wrote an add-in which adds the long complained-about functionality to rename a dimension from within the sketch environment. This is great and all, but it would be even better if the command for it were in the right click context menu for a dimension rather than the top level Sketch menu.
I poked around in the documentation and previous posts on this forum to no avail. There is an example in the documentation to add the command to the context menu for all objects, but I would rather not fill up the global menu since the command is useless for anything except sketch dimensions. Does anyone know if it is possible to do this, and if so, how?
goyals
PFA script showing how to add context specific items in context menu.
Shyam Goyal
Sr. Software Dev. Manager
I am trying to figure out how to add an entry to the existing context menu.  The Marking menu sample shows how to create an entirely new menu, but I'd just like to add . as single command to the existing browser context menu.  How would I do that?
Thanks in advance.
Stephen
Yep, that'd definitely be possible. I wrote an extension which does this exact thing, it's available at https://github.com/lf-/renamethisdimension
BrianEkins
If you remove the two calls to the "clear" method in the sample you'll see that the sample is demonstrating adding to existing context menus.  It's just that the sample is getting the existing menu, deleting all of the current commands in the menu and then adding the commands it wants.  You have full control over the contents of the menu where you can delete them all, delete a few, and add whatever you want.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Thanks, that's perfect!  Should have been able to figure it our for myself, but it's all pretty new at this point and the obvious stuff seems to hide from me at first.
OceanHydroAU
*Very* cool - thanks for sharing this!!
In case anyone is wondering - this is what it looks like when you right-click:-
And this is the code:
#Author-goyals
#Description-right click context stuff
import adsk.core, adsk.fusion, adsk.cam, traceback
# global mapping list of event handlers to keep them referenced for the duration of the command
#handlers = {}
handlers = []
cmdDefs = []
entities = []
def run(context):
    ui = None
    handlers.clear()
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        def setLinearMarkingMenu(args):
            try:
                menuArgs = adsk.core.MarkingMenuEventArgs.cast(args)
                cmdDefSelectedEntities = ui.commandDefinitions.itemById('PrintSelectedEntities')
                cmdDef = ui.commandDefinitions.itemById('TestCommand')
                commands = []
                commands.append(cmdDefSelectedEntities)
                commands.append(cmdDef)
                linearMenu = menuArgs.linearMarkingMenu
                # linear
                linearMenu.clear()
                linearMenu.controls.addCommand(cmdDef)
                linearMenu.controls.addCommand(cmdDefSelectedEntities)
                linearMenu.controls.addSeparator('LinearSeparator')
                dropdown = linearMenu.controls.addDropDown('Linear Sub Menu', '', 'LinearSubMenu')
                subDropDown = dropdown.controls.addDropDown('sub sub', '', 'Sub Sub')
                for cmd in commands:
                    dropdown.controls.addCommand(cmd)
                    subDropDown.controls.addCommand(cmd)
                if args.selectedEntities:
                    sel0 = args.selectedEntities[0]
                    # special command if brep entities selected
                    body = adsk.fusion.BRepBody.cast(sel0)
                    face = adsk.fusion.BRepFace.cast(sel0)
                    edge = adsk.fusion.BRepEdge.cast(sel0)
                    vertex = adsk.fusion.BRepVertex.cast(sel0)
                    if body or face or edge or vertex:
                        cmdDefSpecial = ui.commandDefinitions.itemById('BrepCommand')
                        linearMenu.controls.addCommand(cmdDefSpecial)
                    # special command if sketch entities selected
                    sketch = adsk.fusion.Sketch.cast(sel0)
                    prof = adsk.fusion.Profile.cast(sel0)
                    sketchEntity = adsk.fusion.SketchEntity.cast(sel0)
                    if sketch or sketchEntity or prof:
                        cmdDefSpecial = ui.commandDefinitions.itemById('SketchCommand')
            except:
                if ui:
                    ui.messageBox('setting linear menu failed: {}').format(traceback.format_exc())
        def setRadialMarkingMenu(args):
            try:
                radialMenu = menuArgs.radialMarkingMenu
                # radial
                radialMenu.clear()
                subRadial = radialMenu.create("test")
                subRadial.text = "sub"
                subsubRadial = subRadial.create('sub sub')
                # sub sub
                subsubRadial.westCommand = cmdDef
                subsubRadial.northCommand = cmdDef
                subsubRadial.southCommand = cmdDefSelectedEntities
                subsubRadial.eastCommand = cmdDef
                # sub radial menu
                subRadial.northwestCommand = subsubRadial
                subRadial.southeastCommand = cmdDef
                subRadial.southwestCommand = cmdDef
                subRadial.northeastCommand = cmdDefSelectedEntities
                # root radial menu
                radialMenu.eastCommand = cmdDef
                radialMenu.westCommand = cmdDef
                radialMenu.northCommand = cmdDef
                radialMenu.southCommand = cmdDef
                radialMenu.northeastCommand = subRadial
                radialMenu.northwestCommand = cmdDefSelectedEntities
                radialMenu.southeastCommand = cmdDef
                radialMenu.southwestCommand = cmdDef
            except:
                if ui:
                    ui.messageBox('setting radial menu failed: {}').format(traceback.format_exc())
        class MyCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
            def __init__(self):
                super().__init__()
            def notify(self, args):
                try:
                    command = args.command
                    onCommandExcute = MyCommandExecuteHandler()
                    handlers.append(onCommandExcute)
                    command.execute.add(onCommandExcute)
                except:
                    ui.messageBox('command created failed: {}').format(traceback.format_exc())
        class MyCommandExecuteHandler(adsk.core.CommandEventHandler):
            def __init__(self):
                super().__init__()
                try:
                    command = args.firingEvent.sender
                    cmdDef = command.parentCommandDefinition
                    if cmdDef:
                        if cmdDef.id == 'PrintSelectedEntities':
                            if entities:
                                entityList = 'selected entities:'
                                for e in entities:
                                    entityList += '\n' + str(e)
                                ui.messageBox(entityList)
                            else:
                                ui.messageBox('No selected entity.')
                        else:
                            ui.messageBox('command {} triggered.'.format(cmdDef.id))
                    else:
                        ui.messageBox('No CommandDefinition')
                except:
                    if ui:
                        ui.messageBox('command executed failed: {}').format(traceback.format_exc())
        class MyMarkingMenuHandler(adsk.core.MarkingMenuEventHandler):
            def __init__(self):
                super().__init__()
                try:
                    # selected entities
                    global entities
                    entities.clear()
                    entities = args.selectedEntities
                except:
                    if ui:
                        ui.messageBox('Marking Menu Displaying event failed: {}'.format(traceback.format_exc()))
        # Add customized handler for marking menu displaying
        onMarkingMenuDisplaying = MyMarkingMenuHandler()
        handlers.append(onMarkingMenuDisplaying)
        ui.markingMenuDisplaying.add(onMarkingMenuDisplaying)
        # Add customized handler for commands creating
        onCommandCreated = MyCommandCreatedEventHandler()
        handlers.append(onCommandCreated)
        # Create a command to print selected entities
        if not cmdDefSelectedEntities:
            cmdDefSelectedEntities = ui.commandDefinitions.addButtonDefinition('PrintSelectedEntities', 'Print Entities', 'Print selected entities.', './resources/')
            cmdDefSelectedEntities.commandCreated.add(onCommandCreated)
            cmdDefs.append(cmdDefSelectedEntities)
        # Create a test command
        if not cmdDef:
            cmdDef = ui.commandDefinitions.addButtonDefinition('TestCommand', 'Test Command', 'Test Command', './resources')
            cmdDef.commandCreated.add(onCommandCreated)
            cmdDefs.append(cmdDef)
        # Create special command for brep entities
        cmdDefBRepSpecial = ui.commandDefinitions.itemById('BrepCommand')
        if not cmdDefBRepSpecial:
            cmdDefBRepSpecial = ui.commandDefinitions.addButtonDefinition('BrepCommand', 'Brep Command', 'This is a command for brep entities.', './resources')
            cmdDefBRepSpecial.commandCreated.add(onCommandCreated)
            cmdDefs.append(cmdDefBRepSpecial)
        # Create special command for sketch entities
        cmdDefSketchSpecial = ui.commandDefinitions.itemById('SketchCommand')
        if not cmdDefSketchSpecial:
            cmdDefSketchSpecial = ui.commandDefinitions.addButtonDefinition('SketchCommand', 'Sketch Command', 'This is a command for sketch entities.', './resources')
            cmdDefSketchSpecial.commandCreated.add(onCommandCreated)
            cmdDefs.append(cmdDefSketchSpecial)
        ui.messageBox('Right click to see the customized marking menu.')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        for obj in cmdDefs:
            if obj.isValid:
                obj.deleteMe()
            else:
                ui.messageBox(str(obj) + ' is not a valid object')
        handlers.clear()
        ui.messageBox('Stop addin')
    except:
        if ui:
and you need to create a folder "resources" inside your add-in folder for this script before it will run (or, if you're lazy, extract the attached zip file into the "Autodesk Fusion 360/API/AddIns" folder).
