Add command button to Fusion Tool Bar Panel
brad.bylls
brad.bylls
Are we allowed to add a command button in the middle of a Fusion drop down?
It works if I add to the bottom of the panel using panel ID 'SolidModifyPanel'
I am trying to add a command button where shown below:
I am trying to use :
ui.allToolbarPanels.itemById('FusionCombineCommand').controls.addSeparator()
And then add the command button.
This is where I get the error:
Brad Bylls
kandennti
Hi @brad.bylls .
Try this.
ui.allToolbarPanels.itemById('SolidModifyPanel').controls.addSeparator('separatorId', 'FusionCombineCommand', False)
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-87a73951-9603-4e29-ba54-ee3529c2dcc3
brad.bylls
Thanks @kandennti
That worked for the separator but I still can't get it to work for the command button.
Brad
Brad Bylls
kandennti
@brad.bylls .
There is no major difference from the separator.
ui.allToolbarPanels.itemById('SolidModifyPanel').controls.addCommand(cmdDef, 'FusionCombineCommand', False)
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-1ed0cfb5-2ad4-4285-9eec-484ef19f2729
brad.bylls
Thank you.
I should have realized that.
Brad Bylls
