'401 - Unauthorized' error in work flow script
We have a revision-controlled workspace set up to create, review, and approve ECOs (Engineering Change Orders).  This has worked well for us for a couple of years, however, now I'm getting the subject fatal error every time I advance an ECO to my 'CCB Review' phase.  I see there is an error being generated in the getApprovers() function (ApprovalBoardLib_Repaired), which is called from two places: GenApprovalBoardApprove and GenApprovalBoardFinalApproval.  The error is occurring at the point it is trying to pull together a list of all identified approvers for that ECO, but I get this fatal error any time I click on the ECO just to access it.  I can't seem to track down exactly what is causing the problem.  Thanks in advance!
ekinsb
I think you may have posted this in the wrong forum.  This forum is for Fusion 360 API questions.
Brian Ekins
Mod the Machine blog
I'm using Fusion 360 and I have what appears to be a script problem.  Is there another forum I should be using?
Check that.... I'm using Fusion Lifecycle.  Sorry about that!
