3 Legged Authentication Via Postman
Hi there,
I am trying to get a three legged Authentication via postman. I went through several to tutorials and I am unable to get the three legged. I got it to work only once and now I am unable to get it to work.
I followed this:
http://adndevblog.typepad.com/cloud_and_mobile/2016/06/using-3-legged-oauth-for-forge-apis-with-post...
My Inputs:
TokenName:
Auth URL: https://developer.api.autodesk.com/authentication/v1/authorize
Access Token URL: https://developer.api.autodesk.com/authentication/v1/gettoken
Client ID: XXXXXXXXXXXXXXXX
Client Secret: XXXXXXXXXXXXXX
Scope: data:read
Grant Type: Authorization Code
Callback URL: https://www.getpostman.com/oauth2/callback
adam.nagy
Autodesk Support
Autodesk Support
Since you could do it once and lots of people (inc. me) can use that workflow without any issues, maybe something went wrong with your Postman installation?
Does it work with other non-Autodesk services that also require 3 legged OAuth?
What exact error are you getting?
Also, since this question is not related to Fusion 360, but Forge, would you mind moving this question to StackOverflow where we provide Forge support?
https://developer.autodesk.com/en/support/get-help
Thank you,
Adam Nagy
Autodesk Platform Services
mona_jalilzadeh1
What is your callback URL? When you are creating your app, make sure to use the postman callback URL:  https://www.getpostman.com/oauth2/callback
You can always modify an existing app's callback URL.
