02:20 AM
Hi All,
I run into a problem: I have an object in the sketch, and this object can not be easily fully constrained (I copied its profile from a photograph). Now I need to paste this unconstrained sketch (but it must preserve dimensions), move and then add other common constraints for both objects.
Since the first unconstrained sketch is fixed, I can not move it and add constraints. If I unfix it, then even single common constraint breaks dimensions of the first sketch.
Is there a way to fix an object in the skecth to preserve its dimensions, but let it be movable?
Since I new to Fusion 360, I must be doing something wrong, so please help me. Many thanks.
