- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
If I sketch a spline, and extrude it, I can use emboss on the curved face. However, if I create a spline, use offset command on it, then extrude that profile, emboss command doesn't work on its face; it is unselectable.
The reason for creating spline and an offset was that later on I can do a cut using same sketch. I guess I can solve this by using two sketches instead of one. But still, a bit odd, since the surface is curved in a single dimension either way. So it kind of sounds like something emboss command should have worked on.
I attached a simple example demonstrating what I was attempting to do.
