Thread view in 2d Drawing
contactP339Z
Observer Observer
contactP339Z
Observer
Observer
Hello
I'm new with F360 and I need a help concerning the symbol of the thread inside the drawing.
I'm sure that this problem has been discussed before but I don't find the topic.
I need to make a drawing of my 3D model. It's a little enclosure with some threads.
When I create the drawing, I don't find the option to transform the rendering of the threads to an ISO standard.
I'm sure that it's possible but I spent a lot of time to try to find video or discussion on the forum without success.
With this type of view is not possible to make a drawing for supplier.
Thank you for your help.
Vincent
jhackney1972
The only method, I can find, is to return to your model and remove the "Modeled" check mark from the hole command or thread command.
John Hackney, Retired
contactP339Z
Observer
Observer
Hello
Thank you for your post. It works now.
I will continue and try now  to find method to define the type of line used (dash, width,...).
Best regards
Vincent
