Thread create failed
tinglett
tinglett
This might be a cascading set of problems.  Here's a link to the design:  https://a360.co/2L0GV0s
I'm designing a frame with some cross rods that should be threaded on the ends.  It's real simple and looks like this:
0.5" Rod needing threads0.5" Rod needing threads
This rod is a 0.5" pipe created from a path from a sketch (more on that in a minute).   Then I try to use the thread tool to give it threads.  I don't really want a fully threaded rod, but for this report I just took the defaults.  Note that I selected the rod, and the body of the rod almost disappears during the operation (note the end face only is visible).Thread dialog with defaultsThread dialog with defaults
When I hit ok, I get this error.Thread errorThread error
I'm not sure what I'm doing wrong.  This worked easy peasy in the past.
Another thing that is really odd is that the sketch I used to create the rod has a couple mystery projections I can't delete.  Well, I did delete them, but Fusion 360 still thinks they are there.  The "manage lost projections" dialog can show them to me, but try as I might, I can't seem to use that dialog to get rid of that.  Anyway, that's why there is a warning on that sketch.   Would be nice to figure that one out too as I keep thinking I have a problem there :(.
Todd
TheCADWhisperer
Let's put down the mouse and take a walk out to the shop floor.
Pick up the rod.
In the real world - how would you put a bend in the rod without, well, bending the rod?
I think if you edit the Cross Rod Path to add a bend (Fillet) you will find that the thread features work (on both ends), be sure to uncheck Full Length so that you can specify the desired thread length.
This a Bend in RodThis a Bend in Rod
tinglett
Well dang, go figure.   The funny thing was that I was getting this error even though I was trying to specify only 0.75 length of threads, but even more funny (if that's the right word) was that I was just thinking I needed to add that fillet on the rod as it is indeed supposed to be bent rather than welded!
It's been a day.  Thanks for the quick response!
I think I'll "fix" the sketch by deleting it and recreating.  That'll be quicker than trying to delete non-existing projections.
Todd
