Parts4Cad Support?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Who does support for the parts4cad plug-in? I've found that parts with a point in the part number don't get assigned the correct part number in Fusion. So a 6.5mm ejector pin from DMS for example will be given the name _AH6, it should be _AH6.5x160. If I select a 6mm pin it imports with the correct name, _AH6x160. I've tested with parts from other suppliers and get the same problem, part numbers are truncated at full stops\decimal points.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
