Fusion Support
not correct lines in Fusion from Autocad dwg or dxf
4 REPLIES 4
558 Views, 4 Replies
I have a problem.
When i upload 2D DWG or DXF file from autocad lines becomes angullar. Why? I draw lines in autocad polilines and splines does not matter.
4 REPLIES 4
ryan.bales
We need to see the drawing to know why its doing this.
Ryan Bales
Fusion 360 Product Support
in reply to: ryan.bales
i attached autocad and fusion files, see below
ryan.bales
So this is because the drawing has components a LONG way away from the origin. This gets translated in Fusion and becomes a graphical issue. I moved the objects in AutoCAD and they are perfectly fine in Fusion:
The E center point is at: X = 265278.6155 Y = -128981.6237 Z = 0.0000 - this is on an object 3.7 units across. You need to move your objects closer to origin.
Ryan Bales
Very thanks ! Its solved.
