Mirroring Component does not Link to Time-Line
Bug:
0) Start new design
1) Create a Component and activate it.
2) Draw a sketch with a rectangle, extrude it. You made a body. (box; somewhere)
3) Mirror Command: Mirror "Component", select the component with the box in the browser or by clicking on the box-body; select some Mirror-Plane from the origin for example. (the plane doe not matter)
4) Click on the Box of the mirrored Component that was created.
Expected behavior: The selected box (body of the mirrored component) should link to the timeline where it was created, in this case the mirror command.
Current behavior: broken. 😞
5) Rght click in the Browser on the mirrored componen -> Find in Timeline.
Expected behavior: guess what.
Current behavior: ... nothing.
Also mirroring Components seems to be very broken in general. I have an inserted/linked component, that is multiplied (after insertion) by mirroring several times. So one component becomes 2, then 4 then 8 then 16 with four mirror operations. When the linked component is updated (no change to the bodies or whatever, even just inserting a section analysis and saving again), updating the component smashes all mirror operations. Somehow, it only remembers only the first selected item. I try to concentrate that bug into an easy step by step thingy too.
Sorry if its a duplicate. Not really, should be fixed, if so 😛
