I am making a parametric part that calculates some dimensions based on parameters that are in newtons (N) it is essentially a fully stressed beam. It seems that fusion wont allow me to use the force parameter to calculate the distance?
R1 is my reaction force in N
the equation i am trying to use is:
=(300*R1)/83.33E+3
I have also tried
=((300*R1)/83.33E+3) * 1mm
Any help is greatly appreciated
I could just put it in as a distance parameter and note it in the comments but that feels wrong
Solved by g-andresen. Go to Solution.
Solved by HughesTooling. Go to Solution.
Is R1 a parameter? It it is you need to cancel its units. Something like (300*R1/N).
Mark
Mark Hughes
Owner, Hughes Tooling
