When trying to insert SVG or DXF file into fusion 360 , fusion 360 crashes right after you select " Browse Computer". Program just instantly crashes , this is repeatable , and does it every single time. Used to work before updates. Any assistance with this would be appreciated !
Solved by HughesTooling. Go to Solution.
When you say crash, does Fusion just freeze or does it close and disappear? Have you tried a clean uninstall using the tool here?
Mark
Mark Hughes
Owner, Hughes Tooling
The program crashes before the file has a chance to be selected , as soon as I click on " Browse Computer" for file it crashes and closes out of program immeadiatly.
