Hello.
I'm having lot's of trouble trying to install add-ins.
Every add-ins from the fusion app store have failed to install. I tried de-installing fusion and making a fresh install. I updated my mac os to the latest version. And it's still not working.
I checked on the forum and could't see a post resolving the "before" installation troubleshooting.
Hope someone can help me figure this one out.
Cheers,
fred
Hi @fredgab,
Sorry to hear that! Do you have an example add-in that I can test on my Mac? Fortunately, we should be able to manually add the add-in via the Scripts and Add-Ins tool within Fusion 360. The installer just automatically installs it to Fusion for you. You may have to extract it from the package file first however. I can create a step by step for you if you want to provide an example add-in.
thank you for your fast reply.
The latest one I tried to install is this one:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=2857656002406992603&os=Mac&appLang=en
Unfortunately I can't figure out how to go past the installation process, I'd be ok to install them all manualy.
Thank you very much,
Fred
Hi @fredgab,
This is a bit complicated, but it is doable. The first steps we need to do is create a bundle from the .pkg file that you download. To do this:
I have attached the .bundle file below.
The next steps outline adding the .bundle file manually to Fusion
I've been trying to install the Shaper add-in for a couple months on my MacBook with no success. I could get other add-in's to install but not that one. It would seem like it installed but never quite did. I just found this post and tried it and it worked! Thank you James!
Blake
That's not the name of the file and terminal commands don't work. still having the installation fail. any other ideas?
What a gigantic pain in the ass! What's the point of an integrated app store if I have to jump through a million hoops to install a simple plugin?
Excellent explanation, thank you. Should mention that Archive Utility is ordinarily hidden on the Mac, so, in Finder you have to:
Go > Go To Folder > /System/Library/CoreServices/Applications
in order to reveal it.
I must say this is a horribly complicated way to load add-ins. The whole point of the Autocad app store should be to make to process seamless. Why not just deliver the payload bundle and install it directly into /Users/<name>/Library/Application Support/Autodesk/ApplicationPlugins?
Thanks, this really helped in installing the Shaper Add-in. Once you get to the payload file you can also right-click on it, then > open with Archive Utility to get the *.bundle file.
So seamless. Here we are 4 years later and we still have the same problem. If this was iOS we’d be saying do you remember when Apple brought out the iPhone. What were they thinking. 😊
