I made an object on fusion 360 the dimensions are 120mm long 9mm on one end and 18mm on the other end a cylinder object. dimensions were in MM. when I export to Cura slicer my dimensions are wrong I keep getting 35mm x 35mm x 120mm . only one dimension is correct I added the barbarian add-on still no luck fusion
Hi @neogeo3636,
I didnt see any problems sending a .stl file from fusion to cura.
the dimension you see 18.0 X 18.0 X 120.0 mm is the bounding box for the taper.
Im not sure how you got, 35.0 X 35.0 X 120.0 mm.
Can you please the attach the .f3d design that you have created in Fusion 360?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaCan't find what you're looking for? Ask the community or share your knowledge.
