Fusion Support
Flat pattern DXF exports still have issues
4 REPLIES 4
carl.j.barker
164 Views, 4 Replies
Flat patterns containing arcs or ellipses still export badly.
EG.
Flat as displayed in Fusion.
Flat when exported to DXF, viewed in Autocad.
4 REPLIES 4
g-andresen
in reply to: carl.j.barker
just try "Spline to Polyline" first
günther
All the problem curves are ellipses.
This is what Rhino reports on the 3 curves. Doesn't even reimport into Fusion correctly either!
Creating a sketch on the face, projecting then exporting the sketch does work correctly but rotated 180°. Save DXF is also creating ellipses but without the problem!
Mark Hughes
Owner, Hughes Tooling
@jeff_strater  Who would be best to tag in for problems with the flat pattern export? Looks like ellipses are mirrored or exporting the wrong quadrant.
Mark
Mark Hughes
I created FUS-105274 for this issue
Jeff Strater
Engineering Director
Technology Administrators
