Files Read Only
Files Read Only
CNCBits
Files Read Only
CNCBits
After the last major update if I start fusion 360 offline my files are read only and it says my subscription has expired. I have an educational subscription. Once restarted online everything is normal
patilsm
Hi @CNCBits,
Thanks for posting. Once you are in offline mode then your data is ready only mode, If that data is in your cashes or already opened, then even you go offline then also you can access those data. Otherwise you need to go online to access data.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
CNCBits
Hi @patilsm I have found even if I save safe data in the offline cache it still opens as read only.
