I have set a concrete tile texture to faces, and when I take the section view the face texture does not show.
Please, see the attachment.
Solved by ryan.bales. Go to Solution.
in cross-sectional views, the sections are generally hatched, not only in CAD.
günther
Yes of course, but not faces that are not "cut" with section plane, right?
I hadn't registered it exactly but could now state that the section views don't show any appearences but only the physical material.
günther
That does indeed look like a bug.
@ryan.bales can you loo into this and send this to the drawing team ?
I'd love to, but i can't reproduce it yet. I'm using customized appearances that are modified in color and scale. I don't have any custom ones but that could be the issue.
What if you place a different appearance to desks bottom face only? Like first to add a wood texture to whole top part and then some other appearance to bottom face.
Eh i'll have to test a different file - those are 3D wood which cannot be applied to a face.
Yeah figured out. It's only when its applied at face level, the section view applies the default appearance. Its a defect of sorts.
But this has a clear workaround - make the concrete tiles a small body and make the entire body the same appearance.
