F360 Engraving Wont Engrave Contour Selection
bdhowey
Message 1 of 8
bdhowey
The dot is correct the lower section wont engrave the outer profile. Can anyone please help me out with a hint to fix this?
Replies (7)
Message 2 of 8
jhackney1972
Please attach your model so the forum users can take a look at it.  To attach your file, open it in Fusion 360, select the File menu, then Export and save it to your hard drive. Then attach in to a forum post using the Attachments section.
John Hackney, Retired
Message 3 of 8
bdhowey
Hey thanks for the heads up. I have attached the file.
Message 4 of 8
jhackney1972
I played with it quite awhile and had no luck.  Maybe @seth.madore might be able to give you some ideas.
Message 5 of 8
seth.madore
I'm not having any luck with this. There must be something about the sketch that it's not liking at all. The thing is, it does appear to be fully complete, as we can extrude without issue. I'm sending this up the chain, I've opened up CAM-23890 to investigate.
As a workaround, it MAY be possible to redraw this with less segments (use larger 3-point arcs) and have success
Seth Madore
Message 6 of 8
bdhowey
Thank you for putting in the time to check it out.
Message 7 of 8
bdhowey
Thank you for checking this out. I was afraid that ill have to redraw it, not an uncommon problem. It is strange that it press/pulled correctly and appears to be closed properly.
Message 8 of 8
bdhowey
Any luck at figuring out this issue any further?
