Problem when left to right sweep selection
William_Dec_45
William_Dec_45
I occasionally get this problem when I try to select with a left to right mouse sweep. Any help will be appreciated. (See attached image)
jhackney1972
The next time you get this issue, press and release the "1" key.  If you happen to press "2" before you try and left to right left mouse button drag, you are place into "Freeform Selection mode.  It will stick until you press 1 to return to the window selection mode.  Press "3" will give you a different mode also.
John Hackney, Retired
William_Dec_45
Thank you. I will try that.
