Hi.
Since the last update on July 19, the external editor has stopped working. I have redefined it in the preferences, as seen in the capture.external editor
Before the update it worked without problems.
It is not an error that prevents me from working, but it is annoying to have to open from the external program, one by one, the generated programs.
Does anyone know if something has changed so that this option has stopped working?
Thank you and sorry for my bad English.
Solved by HughesTooling. Go to Solution.
There is a bug where using Fusion's CAM task manager makes Fusion ignore the external text editor setting. Try setting to use notepad then change back to your preferred editor. You have to change to a different editor post something then change back to get it working again.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks for the reply.
I've tried it and it has not worked, I hope they solve this little bug in future updates.
Thank you.
