Drawing don't launch
Message 1 of 13
Since ca. 2 weeks the drawing tool cannot Launch.
I did reinstall but it won't work.
Please for help!
Best,
Floriandrawings cannot launchdrawings cannot launch
Replies (12)
Message 2 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Can you check something for me quick? We are working on identifying why this issue is happening to some users and we believe it may be due to locale.
If you open your Region and Language settings from the Control Panel and navigate to the Administrative section, there is a Locale option. What is yours set to? If it is not English (US), can you try setting it here (as a test) and then restarting your computer and launching the drawings module in Fusion.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Message 3 of 13
Dear James
Message 4 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Hmm, thanks for sharing. Can you also try changing the format and location too to English (US) for testing purposes. If it does not work, please change them all back to what you had originally. I have one more idea if that does not work. Please let me know.
James Youmatz
Message 5 of 13
It does not work.?
Message 6 of 13
Dear James,
it would not work any more. I tried all your proposals! Pleas for help!!
Best regards,
Florian
Message 7 of 13
test objecttest objectstarting drawing failstarting drawing fail
Message 8 of 13
cmiller66
Hi zillflor,
I'm sorry to hear you're having an issue with drawings.  I'm assuming you're on Windows.  Can you please try the following:
1. Close Fusion > Launch Windows Task Manager > Are there any AcCoreConsole or Fusion Drawings Console processes still running?  If so End Process for these
2. Launch Windows Explorer > Enter %LOCALAPPDATA% as the folder
3. Open Autodesk\Autodesk Fusion 360, you should see a folder named AcCore
4. Rename the folder (AcCore_BAK) > Launch Fusion and try to open or create a drawing
If this solves your problem please let me know and if you can, please zip up and send me ([email protected]) both the BAK and new AcCore folders.
If this doesn't fix the problem, what OS are you using?  Is the system locale/format set to English or something else?
Chris
Message 9 of 13
Hi Chris,
it wont't work.
I use Windows 7.
Language and Country Setting are Deutsch/Österreich. (german/Austria)
Please for any other proposal.
Florian
Message 10 of 13
cmiller66
Hi Florian,
I sent you a private message.  Please launch Fusion and allow the latest update to install (if you haven't already), then try the steps I sent you.  Please let me know how it goes.
Chris
Message 11 of 13
Hi Chris,
it wont't work.
attached the zipped files.
Please for help.
Florian
Message 12 of 13
zanderadi
I am experiencing the same problem. Have you found a solution?
Thank you.
Message 13 of 13
fenton_webb
Hi all,
yes, we have a solution for you...
https://forums.autodesk.com/t5/fusion-360-support/2d-drawing-not-opening/td-p/8219894
I hope this solves your issue
Fenton Webb
AutoCAD Engineering
