Fusion Support
Dimensions in sketch disappear
7 REPLIES 7
Message 1 of 8
birr5J2RN
366 Views, 7 Replies
Using Fusion 360, Trying to dimension a sketch, after adding the dimension it disappears.
The dimension lines and arrows show up but no numbers.
Any ideas?
7 REPLIES 7
Message 2 of 8
Phil.E
in reply to: birr5J2RN
Sounds like a graphics issue.
Could you please show a screenshot of the entire Fusion application frame with some of these dimensions included?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
birr5J2RN
in reply to: Phil.E
When I dimension the rectangle the value will not show up the same with circle. When I come out of the dimension tool they will show up, if I double click on them to change the value nothing happens and I can not change the size.
Message 4 of 8
TheCADWhisperer
Try toggling Show Dimensions off and then back on.
Do they reappear?
What graphics card/driver are you running?
Message 5 of 8
birr5J2RN
When I toggle dimensions on and off they do appear but will not edit still. Graphics card see image.Graphics card.PNG
Message 6 of 8
Phil.E
Go to AMD's driver site and see if there's an updated driver for your video card please.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 8
birr5J2RN
Graphics Card on the computer screen is up to date.
I have multiple monitors one being a TV so that I can demonstrate the software to my students.
What I discovered this morning is that the actual measurement window that shows up when you go to edit a dimension is actually across the room on the TV screen.
Now I have to figure out how to keep it on one screen.
Message 8 of 8
Phil.E
Resetting the layout might help.
Go to File > View > Reset to default layout
Does that help?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
