Convert STL mesh to solid model
I've been trying to convert this STL to a solid body (so I can edit it and add a few things, carve in it and stuff) with merged faces but the result is an empty mesh with too much faces.... (been converting to BRep, in patch, selecting faces to merge but error).
I'm very noob at Fusion 360
Replies (9)
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
I found that I could stitch and make it solid by upping the tolerance a bit.
Does that work for you?
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
hi Karina!
no, I cant even upping the tolerance, still an empty shell/mesh without
curves.... don't know what to do, it's supposed to be smooth
TheCADWhisperer
There are no curves in an stl file - only straight lines and triangular planar surfaces.
If you want smooth curves - I recommend that you model from scratch.
Is this a school project?
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Can you please make a screencast of the workflow you're using?
If I can see your process, I can see where there might be something you can change.
Cheers,
Karina
Karina Harper
i think I've made something, now I can merge faces, but still an empty shell
TheCADWhisperer
Does it look something like this (see Attached)?
Solid BodySolid Body
that's why I've clicked on convert to Brep, to make a solid body where I
can merge those triangular faces and ending with a curve. Even if I can
merge some of the faces, the program makes strange forms, don't know why :'(
I've seen a video of how to do it on YT, but for me, it doesn't work with
this model....
No, it's not a school project, it's something I've been trying to do on my
own for a couple of months now.
I play airsoft and I want to try and make my own bb replica, but it's very
hard.
P.d. screencast keeps crashing after recordings, probably because it's an
old pc....
TheCADWhisperer
Did you examine the *.f3d file that I posted above?
Bottom line - *.stl is rubbish.
Do not use other stl rubbish.
Design the geometry yourself as native geometry and you will have much better geometry.
You can use the stl as reference in creating proper geometry.
30,000 beginners a day post here trying to put lipstick on stl pigs - it just doesn't work.
(OK, I might have overestimated by a couple of hundred.)
yeah, exactly like that but empty!!!
Already checked, same as what I wanted, thx btw! going to modify to end the project.
what are the steps you made?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
