Change hole diamter
LiveLover
Change hole diamter
LiveLover
I did hole feature on a body face.
How can I change it's diameter?
jhackney1972
Something is going on with this file.  Please attach it for analysis by the forum users.
John Hackney, Retired
jeff_strater
You've selected "Tapped" as the hole type.  For Tapped holes, the diameter is not editable.  You instead pick the hole size by selecting Thread Type, Size, Designation, Class, etc.
Jeff Strater
Engineering Director
rbVFKGN
Observer
Observer
How about after a design is finished and the NC file is posted and tested but the hole size needs to be changed? It appears to be impossible to change the size of a hole without starting all over again with a completely new sketch.
Why is Fusion so *&(##% miserably difficult to perform such simple tasks? Every online video shows a method which apparently no longer exists. Are there any step by step, up to date, instruction videos that show how to do what should be such simple tasks?
jeff_strater
"It appears to be impossible to change the size of a hole without starting all over again with a completely new sketch."
Can you share a design in which this is the case?  There should be no circumstances in which you need a new sketch to change a hole.  If the "hole" is made with a circle in a sketch + an extrude cut, you just edit the sketch and edit the dimension of the circle, exit the sketch, and the extrude will update.  If the hole was made with the Hole command, simply editing the hole feature and changing the dimension will update the hole.
Jeff Strater
