I opened it online and there I can at least view it without any apparent errors. I tried downloading it as a Fusion 360 Archive but then when uploading it back in Fusion I was still not able to open it.
I would guess something in the new version(s) of Fusion is not compatible anymore with something inside that file. And that would be BAD!
You are correct it would be bad.
Can you attach the design here? It might help to have the design in question to examine and debug with.
Do you find this happening with other similar designs you have saved prior to this week?
A related topic:
As mentioned above, I downloaded an archive of the project via the online viewer and then reuploaded it to Fusion in a folder named "Test". It did not help opening the file and now I can't delete that folder and its contents.
I believe you got my email. Please let me know if not.
Regarding deleting a linked design:
If the design is entirely within one folder (as you describe) it can be deleted. Really all linked designs are this way.
In order of dependencies:
Once you have done that, it should be possible to delete the folder entirely, or just the part files themselves.
Hi @keqingsong
Indeed, I can open the project now. Thanks (and thanks again @Phil.E for your earlier help with this).
