RESOLVED: Render Gallery not Displaying on Mac
James.Youmatz
Autodesk Support Autodesk Support
James.Youmatz
Autodesk Support
Autodesk Support
Are you experiencing the render gallery not displaying or stuck in a loading screen for Mac OS? We are currently investigating this issue and working hard to get this resolved.
To workaround this - navigate to the URL below to download the completed renders from Fusion 360:
https://rendering-beta.360.autodesk.com/myrenderings
More information can be found in this thread below:
https://forums.autodesk.com/t5/fusion-360-support/rendering-gallery-is-not-responding/m-p/8066344#M2...
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
pawel.potyrala
Another workaround that works to some extent is to switch from Render to Model work space and back.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
jheinzmann
Its correct that you can download already rendered images thru the web interface.
The more serious problem with this is that I can't render any new images, the 'Render' button is always ghosted. Is there a work around that allows me to start new renderings?
darran
Hi James, thanks for posting here. May I suggest that this issue be flagged on https://health.autodesk.com? At the moment there is nothing showing there to indicate the service is degraded – even if it is only affecting Mac users.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @darran,
I will go ahead and pass this feedback along.
In the meantime, another workaround we have discovered is toggling into offline mode.
James Youmatz
stephen.m.hill
This issue still seems to be on-going.
James.Youmatz
Autodesk Support
Autodesk Support
Hi everyone,
This issue should now be resolved.
James Youmatz
