Branching for simulation
SlawsonEngineering
SlawsonEngineering
Does this work for simulation?  I would like to analyze a part, then branch and make changes to the part.  My hope is that the branch will keep all the load cases and everything, and then if it improves the part, I can push it back to the master.  Is this possible, or is there another work flow that will work better?
charegb
Yes, if you create the studies/load cases and then create branches after that, the studies will be included so that you can do your design variations in the branch and test them with one click.
Looking forward to hearing about your experience as you try this workflow.
Bankim
