A new browser Bug
A new browser Bug
daniel_lyall
Mentor Mentor
A new browser Bug
daniel_lyall
The last bug I posted about is gone, Thanks for that.
This one is along the same line if I put the dimensions into the first box fast or slow it's fine
When I go to do the next diamention If I do it too slowly it loses focus, If I do it as fast as I can it's ok. Not to bad of a bug
When I was putting the screen cast together I found another one If i did the squire and got it sorted and deleted it so I could show doing the Dimension slow,
The squire would not delete properly even after highlighting it and hitting delete on the keyboard the sketch is gone from the tree just not the squire from the drawing area. if I right click on the sketch and select delete the same thing will happen.
See the attached screencast, It shows 3 attempts at doing the squire and 3 attempts at deleting the sketch I paused the vid in between each attempted actions.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
RajkumarIlanchelian
Thanks Daniel for continuously using Fusion browser access and taking the time to provide feedback.
1. The slowness of the dimension is one that we have captured internally and looking to see how we can solve it immediately. (FZC-1685 - internal reference)
2. Regarding the delete of the sketch let me try to reproduce this internally and get it logged for a solution (FZC-1685 - internal reference)
Thanks once again for reporting these.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
