Hey guys, so im posting to a hardinge lathe with an inverted x axis (program needs to read negative x axis to conduct a regular movement). Im not sure what post can allow me to do that, or if i need to edit a post, im also unsure on how to do that as well.
Solved by seth.madore. Go to Solution.
The Fanuc Turning will give you negative X values, provided you set your Turret number to the correct value, as shown in the above photo
How do i change over to turret 101, im looking at the post in fusion, and it does give me a type but no QTCP for x post. Only have g53 x axis.
Oh, I'm sorry, we do that in our Tool Library:
Thanks for your help, it ended up working out!
