SYNTEC postprocessor for Fusion 360
lemonadecat
Message 1 of 20
lemonadecat
Any idea how to get SYNTEC 6MD postprocessor for FUSION 360? I know that some companies could make it special for me, but that is too expensive. In one forum post I noticed that Fanuc postprocessor is pretty similar to Syntec 900 (??) one, but not sure if Syntec 6MD is similar too. Is it really that easy to make that postprocessor and everything will work?
Replies (19)
Message 2 of 20
LibertyMachine
Is this a mill or a lathe?
Hacking up the Fanuc post can sometimes be quite easy, depending on what you need done.
My advice? Take proven code that you have run on your machine and compare the format to what is output by the generic Fanuc post. Placement of M codes is somewhat irrelevant, but the G code placement could effect results, Also of note is the toolchange formatting as well as the zero return functions. How the 6MD handles arcs, cutter comp, tool offsets is also a consideration.
If you post up what your code NEEDS to be, we might be able to better advise you
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 20
lemonadecat
Machine is mill. And machine is pretty new. Nothing is made with it yet because we have no correct postprocessor, so we have no proven code. CNC is 4 axis but 4th axis is turning to 90 degrees on two sides. I hope that I wrote it correctly.
Message 4 of 20
kouar.mohammed
i have made some changes on Fanuc post processor for my syntec 21MA, and it's been working just fine,
just disable "use sequence numbers" before you post your code.
Message 5 of 20
Hi .. I have a CNC with a Syntec 6MD controller .. I have been working with the Fusion 360 post processor for days but I still have several problems .. the CNC is 4 axes with spindle + - 90 degrees ..
If someone achieved good results, I would appreciate it.
Regards!
Message 6 of 20
seth.madore
@Anonymous  what issues are you encountering? There is a Fanuc A axis post that might give you a good starting point.
Seth Madore
Message 7 of 20
Hi Seth, thanks for your answer ..
Yes, that's what I started with ... FANUC and FANUC with axis A ..
I made the changes that correspond to the Syntec commands ... like for example. G20 / 21 for G70 / 71 ... and several modifications more ...
I try to perform a simple process like making 3 holes in a cube ... upper perforation, right and left ... but I can not get it to behave correctly ...
It is a CNC router with 4 axes ... and according to what I understood ... the fourth axis would be the B axis, since it rotates + - 90 degrees on the axis of the Y ... correct me if I am not in the true. .
This was also modified in the post-processor code and now I can rotate this axis according to the design ... but the coordinates are not as expected.
I appreciate your collaborations ..
Message 8 of 20
seth.madore
Can you share your Fusion file here so I can see your setups, as well as your post processor?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Or, just put both the file and the post processor into a .zip file and attach that
Seth Madore
Message 9 of 20
Yeah sure ..
Thank you !
Message 10 of 20
With this second test I have achieved many better results (although I still have doubts about whether it is the correct method).
What is missing here is to compensate the distance of rotation from the center of rotation of the shaft so that when it is positioned for lateral drilling, it is at the correct distance.
It is not calculating the displacement of the rotation of the head ... and I do not know where I should load that parameter ... either in the CAM, in the post-processor or in the Syntec controller ...
Message 11 of 20
seth.madore
Describe the kinematics of the machine. Standard 3 axis with a rotary unit for part indexing? Your description leads me to think you may have a rotating head; is that the case?
A photo of the machine would be VERY helpful
Seth Madore
Message 12 of 20
It is correct .. it is a cnc with rotation of the spindle, the center of rotation is on the Y axis .. that is that it rotates parallel to the X axis ..
It can rotate 180 degrees .. +90 -90 ..
Message 13 of 20
Hello Seth .. After a long weekend of reading and many tests ..
I see that maybe my problem is in TCP programming in the postprocessor ... in some publications about this I have seen some information ... but I can not make it work ...
Have you seen any of this?
Thanks again ..
Message 14 of 20
Hi Kouar,
Thanks for the Syntec 21MA POST. We are about to take delivery of a Syntec 21MA controlled CNC so we would like to use your POST. Do you mind detailing what you changed from the generic Fanac POST to make it suitable? It would also be really helpful to understand what you have tested and running safely e.g. basic 3 axis G code would be a given. Tool changer? 4th Axis? Auto tool height registration? Any more sophisticated functionality?
Many thanks in advance!
Cheers Pete
Message 15 of 20
Dear Michel,
hope you are well, I have seen your conversation, and your problem it looks same my with the same machine and same controller, I wanted to ask you if you fond a solve?
if yes can you share your post-processor withe me?
I look forward to hearing from you.
Message 16 of 20
cheewantok
Hi Michel,
Have you got your post to work? I'm currently having a new machine with the same issue as well without a post processing.
Hope you can shed some light for me.
Have you gotten your machine to work as intended?
Message 17 of 20
KrupalVala
Hi Everyone,
We have a SYNTEC control Post Processor. This post has not been released yet but it is available in the beta version. You can download it from here.
Before trial on Machine, please test the codes carefully
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 18 of 20
lukasz_musiolBJ6FC
Observer
Observer
Will this post-processor work with the Syntec 610MA? BCAM BCM2131D 5AXIS machine
Message 19 of 20
KrupalVala
Hi @lukasz_musiolBJ6FC ,
The generic SYNTEC milling post processor is available for download. It is fully configured with 5-axis support and includes machine simulation capabilities.
Krupal Vala
Message 20 of 20
frank6Q4WN
Community Visitor
Community Visitor
Hi Michel,
I Have a ARES 410 with  Syntec 60WA control with All-in-one PC Controller, do you have a Post Processer for it?
