Schaublin 140 cnc /Fanuc 21i-TB Postprocessor
peter_ekfeld
Observer Observer
peter_ekfeld
Observer
Observer
Hi! looking for post processor for Schaublin 140 cnc /Fanuc 21i-TB with driven tools,
i have tried a bunch but no one is near the fanuc 21i-tB  im´ using, is there i way to buy a taylor made post processor ?
BR/Peter
serge.quiblier
Hi @peter_ekfeld
When you are looking for a post, or post modifications, you can contact one of our partners.
Given our partners can provide more localized support, we would encourage you to investigate the partners in your area, which can be done through our Services Marketplace.
https://servicesmarketplace.autodesk.com/providers/service-speciality/post-processing
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Infernalmecanix
Hi Peter,
cool machine. I have a Nakamura Tome TW10 with fanuc18iTB. I found something close and modified it a little bit. Maybe you could do the same? Please post and let us know how you get on! Cheers!
peter_ekfeld
Observer
Observer
Thank you for your answer! the thought has struck us but the machine is new to us so i'm not really sure what it´s suppose to post,  it would take me a lot of time to do this on my own without the knowledge to alter postprocessors,
/BR Peter Ekfeldt
Infernalmecanix
Well you have a fanuc 21i controller. Find a machine from another manufacturer with the same controller and layout. Start there. Make a basic turning program, post the output and run it on your machine. Get some sample programs from someone with the same machine and look at the code, hopefully it will be iso standard gcode (most likely). There will be mcodes specific for any special features the machine has. If you can find documentation that will be a big help. Fanuc posts are common. Should be totally possible. If that is not for you contact post providers. They will have done exactly the same thing and have something for sale most likely. Probably not to expensive..
peter_ekfeld
Observer
Observer
Hello!  we have tried this with a few 21i-TB processors,  but the schaublin have some machine specific M-codes/G-codes, but we don´t have the knowledge to change a processor to post our specific codes and build the program in the right order  ,we have not found a fusion 360 partner that could help us make one either..
/BR Peter
seth.madore
/BR Peter
Have you reached out to DSI in the US or CADPRO out of New Zealand?
Seth Madore
