Isel post prosessor not working correctly after Fusion 360 update.
marko.timonen
marko.timonen
Hi!
After last Fusion update Isel post prosessor doesn't work any more with drill/circular pocket milling operation.  I think that it is because plunge / ramp feedrate has changed. Does someone have solution / fix for this?
serge.quiblier
Hello @marko.timonen
Can you describe more precisely what is not working?
Is there something incorrect or missing in the code generated, and can you point us where, please?
Some commented code, before/after will be easier to understand.
Regards
Serge.Q
Technical Consultant
cam.autodesk.com
marko.timonen
Hi!
Plunge / ramp feed rate is 0 with drilling / circular pocket milling. There seems to be same kind of problems with other posts also.
serge.quiblier
In fact the issue is in Fusion.
There is nothing that can be done on the post side to avoid or fix this.
We've resolved the issue internally, and we'll see the issue resolved for the public in a future update.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
cam.autodesk.com
