Problem with circular pattern
Message 1 of 19
A strange problem occurred while generating the circular pattern of the program path. The path for planning a single plane is generated correctly. Unfortunately, if you want to create a circular pattern for 3 planes based on this one correctly made path, there is an error. I compared it with my previous programs for similar circular path patterns and it worked there. Maybe I missed something? Please help.
I paste the link to the file from Fusion, unfortunately I can not attach it for unknown reasons, an error pops up.
https://drive.google.com/file/d/11sffo9yLXjRE5bOOFpWlW831iXybzqth/view?usp=sharing
Replies (18)
Message 2 of 19
daniel_lyall
What file is it, there are a lot of files there.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 19
This is the f3z format from fusion 360.
above I posted a visualization of the problem. Doing one track, the program works. Creating a circular path, unfortunately, an error pops up on the pocket nc postprocessor. The situation is strange, I generated circular paths for the remaining walls and the problem does not occur. Maybe it's a bug once I had another strange problem? Is there a way to generate valid paths?
Message 4 of 19
daniel_lyall
Do a save as on the model break link then post that so it is a .f3d.
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 19
Of course.
D20 files
Message 6 of 19
Captain-DJ
@Anonymous
I think daniel_lyall want a single file here to download.
Your link to the google drive folder have many files...wish is it ?
So go to your fusion360, say export and export to a .f3d file, then add it as an attachment here in this forum.
Message 7 of 19
The number of files is due to several objects in the program: clamping and workpiece. In previous topics I uploaded several files the same as here and it was ok.
I put a single file of the workpiece itself.
Message 8 of 19
daniel_lyall
There is a limited amount of extensions allowed in the forum .f3zd is one that is not, it is a pain.
You need to post the model with toolpaths in it so I can see if it is you or fusion.
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 19
I add a model with paths, unfortunately 2 files because the path references on the model require it.
Message 10 of 19
daniel_lyall
Can you post a model that has worked the error is the A axis is going the wrong way.
Is this the same as what you are seeing
Error: Work plane is not supported: A-228.19 B74.478
Error at line: 634
Error in operation: 'Face8'
Failed while processing onSection() for record 1055.
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 19
My message:
Error: Work plane is not supported: A-228.19 B-60.522
Error at line: 634
Error in operation: 'Face3'
Failed while processing onSection() for record 1077.
The error occurs after I make a circular pattern from a single tool path for an oblique edge. The single tool path for the diagonal path works, unfortunately the circular pattern for it does not.
Message 12 of 19
daniel_lyall
Can you post a working model
Daniel Lyall
The Big Boss
Mach3 User
Message 13 of 19
I put a working path, without a circular pattern.
Message 14 of 19
daniel_lyall
Do you have version one or two pocketNC?
Daniel Lyall
The Big Boss
Mach3 User
Message 15 of 19
Version 1, V1.
Message 16 of 19
daniel_lyall
There's the problem the A axis moves too far for a V1 machine a V2 is fine with how your setup is If you change it's direction so you can have the A tilting a small amount and the B doing all the big angle changes it should be fine.
I will have a play and see what I can come up with.
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 19
Axis B is rotatable, Axis A has a limited range. In another model to which I give the link below, the path was written in such a way as to create one transition on an oblique plane, then a circular pattern was made. The machine then simply rotates the object in the B axis, the angle remains unchanged. If you know the solution, please describe it more thoroughly if it can handle the pictures. Best wishes.
Tetraedr with circular patterns working
Message 18 of 19
daniel_lyall
I deleted and redid the toolpaths the A axis is still going too far(for a V1 machine going by the specks) the B is good now.
If you break link on all the Xref files and post the link to the model it will help I am not sure if what I am seeing is corrupted or not as the toolpath are different if I redo them from scratch using this toot https://pocketnc.com/pages/part-setup  doing a pattern after the fact the toolpath is just going too far in the A axis for a V1 machine A V2 machine has no issues.
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 19
Here it is.
