In the attached image, how come when I run the simulation, it only shows material removed from one side and the other side changes color and is shown as a 90 corner?
Solved by johnswetz1982. Go to Solution.
Barbecue you have your model/component turned on (the grey object). Turn it off and you will see what you are expecting.
I was not calling you barbecue. That is what "because" got spell checked to...
