Example part attaches is reproducing what I just discovered on parts that worked perfectly fine in December, it has these holes in it - 9.5; 9.6; 9.7; 9.8; 9.9 and 10mm in size, tool is 8mm endmill, Fusion will generate 9.6mm and larger ramp toolpaths, but won't for the 9.5mm hole (and smaller)
I noticed this just now when editing a part I made in December, when the 2d contour toolpath with a 8mm tool was set to ramp down a 9.5mm hole, it worked fine before, but now it doesn't, no matter if I enable, disable, or change lead-in and out options, it is almost like a minimum ramp diameter has been imposed, though I don't see any option in the toolpath setup to see or edit it. Error message is just general and meaningless, explains nothing.
Same exact story with 5mm endmill and 6mm holes - since update - Fusion won't generate those toolpaths any more...
edit: attaching pictures of another pre-update toolpath - hit re-generate on it = empty toolpath
this one in particular is 5mm endmill making 6mm holes
Solved by a.laasW8M6T. Go to Solution.
I believe this is a Bug
try selecting an entry point:
That seems to fix it
it is a bug as his previous toolpaths on parts that generated fine no longer generate
see this thread: https://forums.autodesk.com/t5/fusion-360-manufacture/smooth-profile-ramp-glitch/td-p/11658040
It should be fixed in the next release
I can only go off the file that was uploaded and reducing the Lead-in Radius worked fine without selecting an Entry Point so if that is a "bug" then how come it works here without the "workaround" ???
I couldn't get it to produce the toolpath no matter how big, small and even turned off lead-in/outs I used. I thought maybe somehow, if the leads are too big and turned off, it somehow ignores the turned off setting and still uses it to check whether it has room for the cutter inside the contour, but making 0.1mm leadins and outs, turning them on/off, still didn't produce the toolpath. The only thing that helped is the solution workaround mentioned previously.
If using the predrilled option, then it just plunges to full depth and ignores the ramp, which isn't why I use this strategy in the first place.
It did work like you said before Jan update and on my old Win10 machine. This is on a new PC with new Win11 22H2 installed, activated and up to date, and fresh Fusion installation also of course.
As I mentioned I can only speak of the example file that you uploaded, on that file all I did was to change the Lead-in from 2mm Radius to 1mm Radius and it appeared to work fine.
If you have other files that you can upload that have the same issue I can have a go at them if you like, if you are happy to carry on using the workaround then OK.
I am on an old Win 10 PC and the Fusion Build is 2.0.15050
for the sake of it, I just downloaded the file I posted earlier that you say you used for your test, opened in Fusion (2.0.15050 x86_64), put the lead options just like in your screenshot and still it doesn't generate the toolpath for the 9.5mm hole, in short - I can't reproduce what you say worked for you.
edit: and as soon as I pick an entry point anywhere on the part, doesn't even need to be connected to the features used for current toolpath, it generates the 9.5mm hole toolpath with or without lead options used
