This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Pick list configurations
we should be able to make information in a pick list selectable or non-selectable  by an on/off button next to each picklist item. Currently to make information non-selectable from a pick list we have to remove the record/ delete it...
for example: we have a pick list in our Change Order Workspace that tells us what type of change it is- lets say a Picklist called "Change Type" with selectable options of...
1.)Document update
2.) Initial Release
3.) Design Change.
lets say I don't want "document update" to be selectable anymore. the only way to make it non-selectable is to delete it. that causes all the completed change orders that had "document update" selected to be blank now. (BIG PROBLEM)
this will cause problems for our auditors. we should be able to turn on and off selections from a pick list but keep them active so they don't get removed from old change order records. basically just make them not selectable from now on but still active.
9 Comments
fred_smith
I agree. Need a way to disable picks, without re-writing history.
richard.valdez
this is becoming a HUGE problem for our system. in our ever changing manufacturing environment we have products and Work sites that are no longer needed or used. so if we have a picklist that indicates a specific Product or site that is no longer available I need this to be non select able but I still need the history to be available for all existing Change Orders for audits. Deleting the Record in the picklist or Work space is not an option. this should be addressed very soon! the first question in an audit is "if the product is no longer available, then why is it still selectable?" it seem like a smart system like Autodesk should have the option to disable the Picklist vaue without compromising existing Change Orders.
fred_smith
To clarify... I agree that this is an issue with static pick lists. I think the alternative is to move static lists (that you know will grow/change) into a workspace. Then each value can have an on/off flag as you suggest and the pick list can be defined with a filter on that flag. Would this work-around work for you? Or am I missing something?
richard.valdez
Yes, My Lists are set up in Workspaces and picklists set up in other workspaces that pull from thier values, but right now there is no way to turn them off and we absolutely need this.
richard.valdez
the work around should work if I create a new field that is an on/off flag as you suggested. I will play around with this option in our Preview tenant before going live with this Suggestion. I will post back when this is working.
fred_smith
I created a simple workspace called "Pick Lists" for all pick list values with fields "List Name" (string), "Value" (string), "Enabled" (checkbox). Create appropriate permissions, descriptor ("List Name","Value"), and add to "References" on main menu. Then, I created a few records and turned one off. Then I defined a new workspace pick list and set filters for "List Name" and "Enabled" on the pick list.
Add a field to another workspace.
Define the filtered pick list.
Appears just as with a static pick list, but the values are being filtered from the reference "Pick List" workspace.
richard.valdez
I just did the same, this looks like it will work. now I just need to go back through and update all my picklists. I like that the existing Where used records are still listing the disabled records. that will help in audits.
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
