Modern UI - Include Additional Owners in a report
As explained in the post closed few hours ago, the problem in the Modern UI is not solved: Include Additional Owners in a report
Sylvain
2 Comments
PLM-Sylvain.Bailly
Do you have a schedule for the implementation of this idea?
It will be good if it includes the following updates:
- possibility to do a report on the field "Additional Owner"
- possibility to add a filter on the workspace view on the field "Additional Owner"
- have the details of the modification done on the field when an update is done. For the moment, the tab "Change Log" does not provide any information about what was modified (user/group added/removed) as you can see below:
This last part will be a very good improvement from the traceability point of view. Having the red and green color like a modification of a field will be the best to keep the same methodology in the software:
Thank you,
Sylvain
PLM-Sylvain.Bailly
Again me!
We need to have a way to use the import tool on the "Additional Owner" property as well.
It will be helpful to update lot of PLM objects in one clik to add users and/or groups inside the "Additional Owner" property.
Sylvain
