Use Assets cloud folder for custom Threads.
At the moment if you add a custom thread manually you need to keep moving your xml file after as the folder is moved with every update. Makes sense to use the assets cloud folder and let Fusion handle and update where custom threads are stored. Would also mean all your computers would have access to the custom threads.
Thanks Mark
1 Comment
This would be even better if there was a way to access and edit this within fusion, and files made with the custom files would add the necessary metadata to the output so that anyone can open up and view/edit the model you have made.
