Scale sketch based on first placed dimension
When a shape is drawng, it might not be sized correctly. Adding a dimension to an entity may make the sketch blow up if the size changes too much. It would be nice if the entire sketch would scaled based on the first placed dimension.
7 Comments
keqingsong
Status changed to: RUG-jp審査通過
Thanks for the idea - There are technically challenges with our sketch kernel that we need to resolve so that the sketch behaves the way you are describing, hence why I'm archiving this for now. Definitely appreciate you capturing this. Also, Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers increased support from the community.
whunter
One reason to implement this is because many SOLIDWORKS users are used to this.
MTimmis_ADSK
I agree with the above idea, I find this a great feature in Inventor, it would be good to see this transfer over to Fusion 360.
rohit.bapat
Hello All,
I am happy to give an update that we have implemented this feature and should be available in the latest Fusion 360 update.
Please give it a try and let me know if there are any questions or concerns.
Thank you,
Best Regards
Rohit Bapat
(Product Owner, Fusion 360)
robE2PQK
Observer
Hello Rohit Bapat,
I would like to use this new feature, but i can't find any video or explanation of it.
How is it called? Were can i find it? How do i use it?
Best regards,
Rob
rohit.bapat
Sorry for coming late.
Here's a small video I made to help demonstrate how to use the feature. I hope it will be helpful
robE2PQK
Observer
Rohit Bapat,
I didn't knew that it was so easy.
Thanks for your reply and the video.
Kind regards,
Rob
