Through all option for features
When using the press/pull command it is easy to grab the arrow and pull a cut though the part. Sometimes I want to specify that the cut should be through all. To do that I have to move to the dialog to choose that option.
If you grabbed the arrow and pulled an exaggerated distance, Fusion could then default to though all based on how far you have moved past the boundary of the part. Or some other method to determine your intent was though all.
2 Comments
promm
Status changed to: Gathering Support
promm
Status changed to: RUG-jp審査通過
Thank you for your idea - this is getting archived due to lack of votes.
Cheers,
Mike Prom
