Drag knife tool and tool path in 2D cutting
Please consider adding a drag knife to the tool library and adding tool paths specific to using a drag knife.
Please include
  • tool axis offset (distance the tip of the knife is offset from the axis of the spindle)
  • a definable angle between two vectors that should be considered a corner
  • a setting to partially retract the blade tip to allow the knife to pivot/swivel at a corner before plunging back to the full depth of the material
  • feed rate
  • multiple passes for thicker materials
It should that the ability to define cuts of A/B parts of an inlay without using a loop move so that there is no material waste.
Also please see suggestions HERE
Thank you!!
4 Comments
etfrench
I voted for this.  Will that be enough to get it in the next update Smiley Happy
WhiteRoomSkis
I'm working on a tutorial with screen shots and information related to using the Donek Excel Macro to add corner actions to 2D contour toolpath/ g-code generated by F360.
I would be really great to get some help from interested parties and or someone from the development team.
I think there are a lot of users that could benefit from this addition. It would definitely make F360 a more complete package.
WhiteRoomSkis
I've created a tutorial on adding corner actions with the donek excel utility. See the link below.
https://forums.autodesk.com/t5/fusion-360-computer-aided/adding-corner-actions-to-drag-knife-tool-pa...
WhiteRoomSkis
After several months of development and testing we have finished a drag knife add-on for Fusion 360. This add-on creates support for the use of drag knives. Users will now have the ability to generate drag knife specific tool paths from within Fusion 360 after installing the add- on.
Features include the ability to specify swivel height, blade offset and corner tolerance angle. The Drag Knife add-on also supports multiple depth passes. The drag knife add-on is compatible with both OSx and PC versions of Fusion 360.The add-on comes with comprehensive documentation as well as a video to assist users in their workflow.
The Drag Knife add on can be downloaded from the Fusion 360 App store.
(https://apps.autodesk.com/FUSION/en/Home/Index)
It is recommended that users also download and install the free NC Viewer add-on from the Fusion 360 App Store or use the online version which can be found at https://ncviewer.com .
