Welded assemblies are quite common in manufacturing. There are some preparations needed to create a safe and rigid welding connection. An assistant in Fusion to create prepared parts for different types of welding connections and the connection itself would be a great thing for manufacturing and engineering.
Furthermore you need to clarify these welding connections in the technical drawing so here you need some welding symbols as well.
After the welding process is finished it is necessary to post machine your welded parts.
Just a few examples for different welds
Representation of a weld in a technical drawingExample for the preparation of a V-weld
Cheers
Chris
