Currently in the "modify" drop down tab there is Fillet and Chamfer. In the fillet Window you have some option to control the fillet. I would like to have a feature in the fillets window to select a "weld" fillet where the graphic image shown would make the fillet look like it has been welded (stacking dimes) look. It will be helpful to show manufacturing/fabrication/factory this is a welded joint. Bicycle frames, Motorcycle frames and swing arms, Industrial equipment, Heavy machinery, etc.
