Welded fillets
Welded fillets
Currently in the "modify" drop down tab there is Fillet and Chamfer.  In the fillet Window you have some option to control the fillet.  I would like to have a feature in the fillets window to select a "weld" fillet where the graphic image shown would make the fillet look like it has been welded (stacking dimes) look.  It will be helpful to show manufacturing/fabrication/factory this is a welded joint.  Bicycle frames, Motorcycle frames and swing arms, Industrial equipment, Heavy machinery, etc.
2 Comments
philipfrench
You will get more support if you add this to the correct forum.
This is the Fusion Lifecycle Forum. You need Inventor ?
All,
This is for Fusion 360.  There was no drop down selection for Fusion 360.I'll call Autodesk directly.
