Vertical timeline option
Definitely one of my favorite features of Fusion 360 is the timeline. What I'm not sure I like so much is the way the description text of timeline objects can only be viewed on mouse hover, in a tooltip.
If I'm not mistaken, Inventor  has a vertical feature history akin to Fusion 360's timeline. When laid out vertically, description text can be displayed to the right of timeline items. Once you get into the (good) habit of naming your stuff (rule #2), description text really helps getting around projects quickly, but requiring mouse hover to access such valuable information is like reading a newspaper through a keyhole.
I wonder if I'm not the only user who would appreciate an option to display the timeline vertically. Please not that I'm not asking to get rid of the timeline: the vertical layout would be functionally identical to the timeline we have today, just laid out differently to provide a an alternative UX. This, in my opinion, is not a bad thing from Autodesk's perspective as users coming from other CAD applications (including Inventor) would instantly feel more "at home" with the vertical layout, and find the software more compelling.
Thank you!
4 Comments
Agreed.  Put it vertically with the origin, sketches, etc. that are listed vertically now.  Basically, make it like Solidworks, which works very well...  It took me a while to even find the little icons at the bottom, and they're really too small to be useful unless you just happen to be editing the last thing you did, and even then they're too small to quickly click on.
Would like to see this as well.
MAS.DPL
AGREED .. the timeline is THE weak link, and there are LOADS of ideas on here to improve it.....
  • Group by parts
  • Have colour cycling for bodies NOT just components.
  • Folders
  • Book marks
  • Hide hidden icons in time line when body/sketch etc is hidden
CPAC_TD_2013
The "Timeline" needs to break free of the LINE as its ONLY interface. I am not advocating losing the timeline as it is now, only adding other ways to interact with it.
A "Timeline" panel like the project/data panel? Or a separate window?
Inside of this/these more spacious container(s), make the Timeline accessible/viewable in different formats.
-searchable!
-text list/tree
-annotations: visual, text, drawings, audio, etc.
-thumbnail list showing visual snapshots of the model
-folders or other non-linear organization.
-able to display both the current component timeline AND the global timeline at the same time. I want to see my place in the whole timeline even as I am scrubbing within a component. Sometimes I think I am far enough back/forwards in time within the component, only to find my edit was not back/forwards enough for the whole project.
-smart folders to filter/group things. IE all holes, all combines, all objects matching a name/property filter.
-Slicers like Excels pivot tables
-something akin to Excels "trace dependents/precedents."
-a directed acyclic graph (DAG)
This and a number of related timeline improvements that I think should all be related facets of one thing.
https://forums.autodesk.com/t5/fusion-360-ideastation/filter-amp-search-design-history-timeline/idc-...
https://forums.autodesk.com/t5/fusion-360-ideastation/milestone-markers-in-timeline/idi-p/9064827
https://forums.autodesk.com/t5/fusion-360-ideastation/annotating-events-on-timeline/idi-p/8986685
https://forums.autodesk.com/t5/fusion-360-ideastation/timeline-as-text/idi-p/8982478
https://forums.autodesk.com/t5/fusion-360-ideastation/filter-time-line/idi-p/7481142
https://forums.autodesk.com/t5/fusion-360-ideastation/timeline-hotkeys/idi-p/8205647
https://forums.autodesk.com/t5/fusion-360-ideastation/timeline-collapsing-the-dependency-graph/idi-p...
