Variable feedrate
Variable feedrate
I would like to suggest a "variable feetrate" on the tool tab with a minimum and a maximum value.
For example in the part that I attached, the tool start cutting a big chunck of material, but when start cutting the dome the passes are very light and would be nice to be able to speed up the process.
1 Comment
odolyte
I agree, i often have to do rough cut leaving some stock and then a precise mill in a second pass. This ends up in a very long double operation where the cam could be "smart" and cut stock fast and do a precise cut where the part is (as long as we use the same tool for both operation).
This could greatly speed up the milling of lot of parts.
