USE MEASURED VALUE AS A USER PARAMETER
I would like to be able to set a measured value to a user parameter.
4 Comments
promm
Status changed to: 実装済み
laughingcreek,
Did you want to create a driven dimension and then use that driven dimension for another parameter?  Since your post we have added driven dimension to our sketches.
Cheers,
Mike Prom
promm
Status changed to: RUG-jp審査通過
Thank you for idea - this is getting archived due to lack of votes and response for the questions that were asked.
Does this exist now: "create a driven dimension and then use that driven dimension for another parameter"?
I would need to pick the minimum of 2 driven dimensions in a parameter.
Currently don't see how I can achieve this.
Kekkeri
Is there allready a solution for this? Would make my life much easier : )
