Untrim Tool
Untrim Tool
Fusion offers no untrim
while it offers extend, extend is not often the better approach
and untrim would be much faster
it is also a cleaner workflow
the solid modeling heal function can sometimes not solve a problem which is when you have
to go into patch mode and as a designer I rather want to have access to the original surfaces
then having to deal with what result the extend command Fusion gives me to which often are
not ideal - extend surface in general is not an ideal result (not just in Fusion).
https://drive.google.com/file/d/0Byzv_NlyKp_2WWd5NHJNNVJiQzg/view
for the sake of combining solid and surface modeling in a workflow this is a really missing tool
3 Comments
Just ran into this today. A surface trim was inverted on import. Should have been a quick unrim and re-trim. I had to do all kinds of stuff to work around.
cekuhnen
@Anonymous
yeah it seems to me that most people who grew up with solid modelers seem not to value the usability of un trim.
While it is more a tool common in surface modelers Fusion also offers surfaces and thus would benefit from offering this in addition to extend.
what I find most interesting about the pro-extend comment is that untrim gives me the original surface back while extend adjusts the surface and often not in a way I wish it would do it.
Not fusions fault - but extend is a tricky tool - the software has to predict understand how you want to to extend
DWhiteley
This is a must for CNC machining. I know you can patch, but if you get the tangencies wrong then you have bad toolpath. It is much better to un-trim.
Dave
